![Clock Multiplier – Crystal Frequency Generator using PT7C4511 Clock Multiplier – Crystal Frequency Generator using PT7C4511](https://www.electronics-lab.com/wp-content/uploads/2021/07/001-3.jpg)
This is an easy-to-build project and it is the most cost-effective and high-performance frequency multiplier, which instigates analog phase lock loop techniques. The circuit provides high-quality, high-frequency output from lower frequency crystal or clock input. The project can be used as a crystal frequency oscillator, clock multiplier and frequency translation. Using phase-locked-loop (PLL) techniques, the device uses a standard fundamental mode, inexpensive crystal to produce an output clock up to 200Mhz. On-board jumpers are provided to select from nine different multiplication factors, which output many common frequencies. The device also has an output enable pin that tri-states the clock output when the enable pin is taken low. The chip is intended for clock generation and frequency translation with low output jitter.
Clock Multiplier – Crystal Frequency Generator using PT7C4511 – [Link]
