![Closed Loop Analog Position Control using Brushed DC Motor and Potentiometer Closed Loop Analog Position Control using Brushed DC Motor and Potentiometer](https://www.electronics-lab.com/wp-content/uploads/2021/10/003-2.jpg)
The project presented here is a low-cost position control closed-loop analog-servo using brushed DC motor and potentiometer as feedback. This project provides all necessary active functions for a closed-loop servo system using a Brushed DC Motor and potentiometer mounted on the output shaft of the DC Motor with Gear. The project is ideally suited for almost any servo positioning application. Can be used in applications such as side mirror movement control for cars, car head lamp beam control, animatronics, robotics, etc.
Closed Loop Analog Position Control using Brushed DC Motor and Potentiometer – [Link]
Login
