Cocket Nova CH552 Dev Board Features USB-C Programming and Versatile GPIO Options
1.095
Based on the WCH CH552G 8-bit microcontroller the Cocket Nova CH552 Dev Board is a low-cost development board with an enhanced E8051 core clocked at 24MHz. designed for beginners and hobbyists, this compact and cost-effective development board features a USB Type-C interface for power and programming. Additional option include s 17 GPIO pins (shared with USB, LEDs, and boot buttons), 2 PWM outputs, 4 ADC channels, and 6 capacitive touch channels for up to 15 buttons and much more.
The board also has easy expansion capabilities with Qwiic/STEMMA QT connectors. All these features make this device useful for applications including educational purposes, low-power IoT devices, and simple sensor-based projects, where a cost-effective solution with minimal features is sufficient.
Previously we have written various ICs and development boards that are powered by MCUs designed and developed by WCH including LANA TNY-CH32V203, Sipeed Tang Mega 138K, the Adafruit CH552 QT, and much more feel free to check those out if you are interested in the topic.
Cocket Nova CH552 Dev Board Specifications
  • MCU: WCH CH552 8-bit Enhanced USB single-chip MCU
  • CPU: Enhanced E8051 core, clocked at 24MHz
  • Memory:
    • XRAM: 1KB (with DMA support)
    • iRAM: 256B
  • Storage:
    • Code Flash: 16KB
    • Data Flash: 128B (byte-level read/write)
  • USB: USB 2.0 Type-C (12 Mbps) for power and programming
  • Expansion I/Os:
    • 17x GPIO pins (shared with USB, LEDs, and boot button)
    • 2x 8-bit PWM outputs
    • 4x 8-bit ADC channels
    • 6x Capacitive touch channels (up to 15 buttons)
    • 2x UART
    • SPI interface
    • Soft I2C
    • 2x 1mm JST connectors (Qwiic, STEMMA QT compatible)
  • Miscellaneous:
    • Built-in LEDs
    • Neopixel RGB LED on pin 3.3
    • The standard LED on pin 3.4
    • 2x Neopixel RGB LED headers
    • Reset and Boot buttons
  • Dimension: Not Mentioned
The company mentions that the board supports programming with the Arduino IDE, using the SDCC toolchain for programming, making it accessible to a wide range of users looking to experiment with 8-bit MCU systems.
The Cocket Nova CH552 Dev Board is priced at around $6.00 and can be purchased from the UNIT Electronics Tindie store.
About Debashis Das
view all posts by das
