Collect and Export Data From Bluetooth Devices
This project will show how to collect Bluetooth low energy data and export it as. csv.
For this project, I am using a Bluetooth Low Energy USB dongle called BlueIO, which will act as a central device to retrieve data. Hibou Air Quality Monitor which will serve as a peripheral device to transmit the data. The script is simple to use and can be used for other purposes such as store the data in a database or cloud.
Things we need:
Before we start
The article assumes you have some general knowledge of how Bluetooth Low Energy (BLE) work. Since the Chrome Serial specification on Google Chrome is not finalized yet, you will have to go to enable the highlighted flag, and restart Chrome.
open chrome://flags/#enable-experimental-web-platform-features in chrome browser.
In this example, we are going to use JavaScript + html (and some CSS for styling) to setup the BleuIO and quickly start scanning.
Step:
  • Clone the git repository.
    git clone https://github.com/smart-sensor-devices-ab/export_ble_data.git
  • Connect the Bleuio dongle to your computer.
  • Open index.html file
  • Click connect and wait for the device to load on your com port.
  • Select your com port.
  • Scan for BLE devices. (this script only scans for Hibou Devices. You can change the manufacturer value at script.js file)
  • Select the device and start getting data. You will get real-time value on the screen.
  • Once you click on stop getting data. you will see all the data showing on a table between the time period. You can view data or export in csv.
Download: export_ble_data-master.zip
Follow the video for a better understanding
1 Comment
mahi patel
If I see a good post, you will not go without praising me, because every word written in the post you have written is very thoughtful, your way of writing is very beautiful and your views are also very good. This is a commendable post, as much as this post is praised, it is less, you should keep writing more beautiful posts in your life.
