![COM-TGUC6: Compact Solution with 11th Generation Intel® Core™ Processors COM-TGUC6: Compact Solution with 11th Generation Intel® Core™ Processors](https://www.electronics-lab.com/wp-content/uploads/2021/11/COM-TGUC6_3DFront_01.png)
AAEON, a leader in embedded computing solutions, announces the COM-TGUC6, their latest COM Type 6 board, featuring the 11th Generation Intel® Core™ processor. The COM-TGUC6 offers developers and users a significant increase in performance over previous generations of COM boards, with faster memory speeds, greater display support, and higher bandwidth connections. The COM-TGUC6 also delivers a rugged design to work wherever it’s needed.
The COM-TGUC6 brings greater processing performance to embedded computing than before. Along with the 11th Generation Intel Core U processors (formerly Tiger Lake), the COM-TGUC6 delivers faster memory, supporting dual DDR4 modules up to 3200 MHz. The COM-TGUC6 supports in-band ECC, providing memory error detection even with non-ECC memory modules. Together this offers faster, more accurate data processing, vital for increasingly complex applications in robotics and AI computing. Additionally, the COM-TGUC6 can be configured with the industrial grade Intel Core U SKUs, enabling the board to meet WiTAS II wide temperature specifications, providing operation in temperatures from -40°C up to 85°C.
- 11th Generation Intel® Core™ Processor Family (formerly Tiger Lake UP3)
- 2 x SODIMM DDR4 3200MHz Memory, up to 32GB (in-band ECC)
- Intel I225LM Gigabit Ethernet x 1
- VGA, 18/24-bit 2ch LVDS/eDP, DDI x 3
- High Definition Audio Interface
- SATA3.0 x 2
- USB 2.0 x 8, USB 3.2/2.0 x 4 (up to USB 3.2 Gen 2 support)
- PCI-Express [x1] x 5 (Gen3), PEG [x4] x1 (Gen4)
- 12V DC input
- COM Express Type 6, Compact size, 95mm x 95mm
The COM-TGUC6 is designed to bring faster data processing and connections, utilizing the latest generation of I/O and expansion features. One key feature is the Intel® i225LM chipset, powering 2.5 Gbps Ethernet speeds. This enables faster network connections for applications that demand higher bandwidths. Additionally, the system supports four USB3.2 Gen 2 ports, up to eight USB2.0 ports, as well as SATA III storage devices.
The COM-TGUC6 also provides flexible display support, with connections for VGA, up to three DDI ports, and LVDS/eDP support. The board is capable of powering up to four independent displays, perfect for digital signage, medical equipment and gaming. The COM-TGUC6 also supports a range of expansion options including five PCIe Gen 3 lanes, as well as PCI Express Graphics (PEG) Gen 4 [x4].
AAEON provides customers and clients with a range of services to help ensure the right product for the job. From carrier boards and enclosures to OEM/ODM services, AAEON’s industry-leading service and support helps accelerate development and reduce time to market.
more information: https://www.aaeon.com/en/p/com-express-cpu-modules-com-tguc6
