bidrohini
Members
  • Posts
    60
  • Joined
  • Last visited
  • Days Won
    4
bidrohini last won the day on March 19
bidrohini had the most liked content!
2 Followers
Recent Profile Visitors
bidrohini's Achievements
  1. Thanks for sharing the project. Here is another good project based on DHT11. This is done with ESP8266. But it can be done with ESP32 too. This is a room-temperature monitor. We can use it to monitor our room from anywhere in the world with dht11: https://www.pcbway.com/project/shareproject/Room_Temperature_Over_Internet_With_BLYNK_ESP8266_DHT11_91b0d3f5.html
  2. A suitable microcontroller for this project would be the ESP32. It's a budget-friendly microcontroller with built-in Wi-Fi capability, which makes it easy to connect to the internet and fetch real-time data. The ESP32 also has plenty of GPIO pins for controlling multiple bells and interfacing with other peripherals. You can also print PCB of your project from PCBway. https://www.pcbway.com/project/shareproject/ESP32_Power_Montiroing_PZEM_004T_and_Relay_Control_c8098cc0.html
  3. Good project. I can see another ESP32 Webserver for Home Weather Station PCB. https://www.pcbway.com/project/share/ESP32_Webserver_for_Home_Weather_Station.html
  4. Very good project. If you want to customize an ESP32-C3 board of yourself, you can see the BOM here: https://www.pcbway.com/project/shareproject/ESP32_C3_DevBoard_208483e1.html
  5. Thanks a lot for the elaborate tutorial. Here I found another Neopixel ring clock. This one is also nice and well built. https://www.pcbway.com/project/shareproject/NeopixelQuarterRing_cbc70e1a.html
  6. Thanks a lot for sharing this project. Earlier, I came across many telegram-related projects like this. https://www.pcbway.com/blog/PCB_Design_Tutorial/ESP32_CAM_with_Telegram__Take_Photos__Control_Outputs__Sensor_Readings_and_Motio.html Your blog is much more elaborate.
  7. You can post your query to digikey forum.
  8. Thanks for the detailed discussion of the project. Here somebody designed a smaller alternative https://www.pcbway.com/project/shareproject/Atiny_85_crypto_miner_9415f34a.html It is based on Attiny85.
  9. I think for this type of smart projects, you must choose STM microcontrollers. With Arduino, the nearest thing I could find is this one: If you just want to make simple Arduino-based school bell, you can follow this design: https://www.pcbway.com/project/shareproject/Arduino_School_Bell_Simple_DIY_058abe6e.html
  10. Yes. The link I posted. The smart grocery cart project.
  11. If you are interested, you can make a PCB of your project: https://www.pcbway.com/project/shareproject/Battery_powered_and_compact_design_ESP32_temperature_and_humidity_sensor_ba934715.html This PCB also features ESP32 and DTH11. It's quite compact.
  12. Can these modules E73-2G4M04S1A, E73-2G4M04S1B, E73-2G4M08S1C, E73-2G4M04S1D be used instead of ESP8266?
