Jump to content
Electronics-Lab.com Community
How to get higher, high voltage from ingition coil?
russwr
Magneto fired ignition coil is not AC input, as being a single pulse transformer. It fires in milliseconds range. (not fast microseconds range of CDI) How to get the output increased in voltage?????? It is not AC output , and cannot use diode/capacitor multiplier like an AC transformer does. I tried a wound pulse transformer many ways that failed. If CDI was used with PF caps, which would work, the matching inductor for increasing to milliseconds range would be in high, unuseable Henry range inductance. STUMPTED!! The ignition coils are all autotransformers with 3 terminals, not 4 as regular transformers. The primary is connected to the secondary also. I need 8Kv changed to 24Kv. Regular inductive type ignitions only go to 15kv output. I also tried the added magnets to regular flywheel magnet ,to attempt getting a higher voltage going into primary by stronger magnetic field..
Link to comment
Share on other sites
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
