![Constant Current Laser Diode Driver Circuit Using OPA2350 OpAmp Constant Current Laser Diode Driver Circuit Using OPA2350 OpAmp](https://www.electronics-lab.com/wp-content/uploads/2017/01/Laser-Diode-Driver-using-OPA2350-PIC-1.jpg)
The voltage-controlled current source circuit can be used to drive a constant current into a signal or pump laser diode. This simple linear driver provides a cleaner drive current into a laser diode than switching PWM drivers. The basic circuit is that of a Howland current pump with a current booster (Q1) on the output of a R-R CMOS OPA2350 op amp (U1). Laser diode current is sensed by differentially measuring the voltage drop across a shunt resistor (RSHUNT) in series with the laser diode. The output current is controlled by the input voltage (VIN) that comes from Trim pot PR1.
- Supply 3,3V DC
- Load Up to 300mA
- PR1 Trimpot Current Adjust
Constant Current Laser Diode Driver Circuit Using OPA2350 OpAmp – [Link]
Login
