![Continuity Tester using ATtiny85 Continuity Tester using ATtiny85](https://www.electronics-lab.com/wp-content/uploads/2017/11/continuitytesterpcb2-1024x217.jpg)
This article describes a simple continuity tester based on an ATtiny85. The tester features a buzzer that sounds to help you determinate the trace continuity. It is designed for checking circuit wiring, or tracing out the tracks on a PCB. According to it’s author David Johnson-Davies it has a low threshold resistance of 50Ω to avoid false positives, and passes less than 0.1mA through the circuit under test, to avoid affecting sensitive components. It’s powered from a small button cell, and automatically switches itself off when not in use, avoiding the need for an on/off switch.
sir, can you please give me its full circuit diagram ?
Full circuit diagram is on the author’s page.
