![Conventional Flow vs Electron Flow Explained Conventional Flow vs Electron Flow Explained](https://www.electronics-lab.com/wp-content/uploads/2016/06/conventional-flow-vs-electron-fl.jpg)
“baldengineer” explains which way the current flows.
A couple of weeks ago I wrote about four current flow direction myths. As a follow up to that popular post, I decided to dedicate this month’s AddOhms electronics tutorial video to Current Flow. In episode #19, I tackle the question of which way does current flow.
You might have heard about “conventional flow” and “electron flow.” In conventional flow, we assume that current flows from the positive voltage towards the negative voltage. In digital, the “negative voltage” is usually called ground. However, that’s not how the electrons move nor is it how they carry the charge around a circuit path.
Conventional Flow vs Electron Flow Explained – [Link]
Login
