![Convert a $20 Router To Home Automation Gateway For IoT Devices Convert a $20 Router To Home Automation Gateway For IoT Devices](https://www.electronics-lab.com/wp-content/uploads/2019/03/pic_mango_banner_MT300N-V2-1140-e1552903164905.jpg)
WiFi based home automation products are cheaper compared to ZigBee or Z-Wave products, but the downside is that WiFi devices need an internet connection to perform their function. A lot of those IoT devices don’t just communicate on your local network, they also talk to the outside world via the internet. IoT devices like simple smart plugs, sensors, and all kinds of home automation gadgets don’t always have a good reason to connect to the outside world. Letting your home devices controlled by a bunch of cloud servers on the internet may not be the best idea.
Internet connectivity for home devices should be optional – the user should be in charge of deciding whether he/she wants to expose the home-devices to the internet – may be for remote monitoring or controlling purpose. This can be done by making a local gateway for your home automation devices using a cheap $20 pocket router. Here is a guide on how to do this clever hack.
![GL-MT300Nv2 $20 Router](https://www.electronics-lab.com/wp-content/uploads/2019/03/router.jpeg)
This hack depend on the IoT devices themselves, but many of them simply won’t function without access to the internet, but a lot of popular products like sonoff, blitzwolf, teckin etc have been hacked by the open source community to get around that. But jailbreaking solves part of the problem. Still, the need for a home-automation gateway is a challenge and requires some advanced knowledge of setting-up WiFi access point + MQTT broker + automation gateway server.
Albert David (@albert-david.blogspot.com) solved this challenge by modifying the firmware of a GL-MT300Nv2 (a $20 travel router) and converting it to a full-automation-gateway to support following functionalities:
- wifi-access-point
- DHCP and DNS server
- MQTT broker (mosquitto)
- domoticz
![domoticz setup](https://www.electronics-lab.com/wp-content/uploads/2019/03/domoticz-setup.png)
All he did was build his own variant of OpenWRT firmware that includes all necessary components like domoticz and MQTT-broker. Follow the step-by-step method to overwrite the OEM firmware of the router with Albert’s all-in-one custom firmware.
1 – Download the autom8box binary from here.
2 – Power ON your GL-MT300N-V2 box and wait for the device’s SSID to show up on your PC.
3 – With OEM firmware, this device’s SSID is shown as “GL-MT300N-V2-xxx”.
4 – Connect to the AP with default password “goodlife“.
5 – If connected, you can see the IP near the WiFi option. Or by using “ipconfig” (Windows) or “ifconfig” (Linux) command in cmd/terminal.
![Router IP](https://www.electronics-lab.com/wp-content/uploads/2019/03/first-time-setup-3.png)
6 – Open a browser, and enter the following address in the URL field:
http://192.168.8.1/cgi-bin/luci/admin/system/flashops
7 – Login with username “root” and leave the password field empty. After logging in, you’ll see the flashing page.
8 – In the page, make sure the “keep settings” option is unchecked. Select the firmware binary (autom8box-mt300nv2.bin) that you have downloaded already. Click the “Flash Image” button.
![Flashing Procedure](https://www.electronics-lab.com/wp-content/uploads/2019/03/first-time-setup-3-3.png)
9 – Next, click on the “Proceed” button and the flashing process will start. Wait patiently and don’t turn off your router in the middle of flashing.
10 – After 2minutes, check on your PC’s wifi-list, new SSID “autom8box” will show up. “goodlife” is the password.
11 – Open the following URL in the browser – there you go! your new domoticz UI
http://192.168.8.1:8080
![Custom firmware UI](https://www.electronics-lab.com/wp-content/uploads/2019/03/first-time-setup-3-8.png)
You are all set by now. You have your own home-automation gateway. Configure your IoT devices on domoticz as per your need. You have full control over the devices and can flexibly configure all the settings.
