How to Create Inverted Silkscreen in Cadsoft Eagle
If you’re one of EAGLE CAD fans, and you were wondering how some boards like Arduino boards have what’s called a negative silkscreen, hollow rectangles or shapes by text or logo, then you will learn how to do it with Ishaan’s video tutorial.
Ishaan used a ULP called “negasilk.ulp” in his tutorial. It is written by Christian Bohrer, and it can be downloaded here.
We’ve tested  this trick in ElectronicsLab using these steps:
  1. Adding some texts on layer 41tRestrict.
  2. Drawing a rectangular polygon in 1Top layer with width 8 mil (according to Ishaan, this ULP accepts only this width), and don’t forget to hit ratsnest.
  3. Run negasilk.ulp.
  4. A script file is generated in the same directory of your .brd file, open it and make the following modification using any text editor (adding layer 21 line).
    Set Wire_Bend 2;
    LAYER 21;
    GRID MM;
  5. Finally, delete the unwanted polygon and text from layer 41 and layer 1.
You can see these steps in the following GIF(click to view):
steps to generate inverted silkscreen
Steps to Generate Inverted Silkscreen In Eagle CAD
https://www.youtube.com/watch?v=lVpzqZfN2A4&rel=0
Embedded Hardware Engineer interested in open hardware and was born in the same year as Linux. Yahya is the editor-in-chief of Atadiat and believes in the importance of sharing free, practical, spam-free and high quality written content with others. His experience with Embedded Systems includes developing firmware with bare-metal C and Arduino, designing PCB&schematic and content creation.
view all posts by yahya
