![Crocus Technology CT41x XtremeSense® TMR Current Sensors Crocus Technology CT41x XtremeSense® TMR Current Sensors](https://www.electronics-lab.com/wp-content/uploads/2022/04/195418896.png)
Crocus Technology CT41x XtremeSense® TMR Current Sensors are high bandwidth and ultra-low-noise integrated contact current sensors utilizing the patented XtremeSense® TMR technology. The technology enables high accuracy current measurements for many consumer, enterprise, and industrial applications. These components support eight current ranges where the integrated current-carrying conductor (CCC) will handle up to 65A of current and generates a current measurement as a linear analog output voltage. The 8-lead SOIC packaged CT41x sensors achieve a total output error of about ±1.0% full-scale (FS), a 300ns output response time, and a 6.0mA current consumption. A filter function reduces the noise on the output pin.
- Integrated contact sensing for low-to-medium current ranges
- 0 to +20A
- -20A to +20A
- 0 to +30A
- -30A to +30A
- 0 to +50A
- -50A to +50A
- 0 to +65A
- -65A to +65A
- Integrated current-carrying conductor (CCC)
- Linear analog output voltage
- ±1.0% FS total error output
- 1MHz bandwidth
- 300ns response time
- -40°C to +125°C operating temperature range
- UL/IEC 62387 certification
- >2.5kVRMS rated isolation voltage
- >701VRMS working voltage for basic isolation
- >344VRMS working voltage for reinforced isolation
- IEC 61000-4-5 certification
- Low 9.0mARMS to 19.0mARMS noise at fBW = 100kHz
- Supply voltages
- 4.75V to 5.50V for the CT415 and CT418
- 3.0V to 3.6V for the CT416 and CT417
- Filter function to reduce noise on the output pin
- -40dB immunity to common-mode fields
- AEC-Q100 Grade 1 (under qualification)
- 8-lead SOIC package
- RoHS compliant
more information: https://crocus-technology.com
