![CUI’s MEMS Microphones deliver enhanced audio quality CUI’s MEMS Microphones deliver enhanced audio quality](https://www.electronics-lab.com/wp-content/uploads/2019/03/47103.png)
CUI’s analog and digital MEMS microphones deliver enhanced audio quality in extremely compact packages.
CUI’s MEMS microphones provide users with improved audio quality and performance in compact, low-profile packages as small as 2.75 mm x 1.85 mm x 0.95 mm. Featuring sensitivity ratings from -44 dB up to -26 dB, signal-to-noise ratios from 57 dBA up to 65 dBA, and sensitivity tolerances as low as ±1 dB, these MEMS microphones are ideal for a range of portable consumer electronics applications.
- Compact sizes as small as 2.75 mm x 1.85 mm
- Depths as low as 0.95 mm
- Analog and digital pulse density modulation (PDM) output types
- Sensitivity ratings from -44 dB ~ -26 dB
- Sensitivity tolerances as low as ±1 dB
- Signal-to-noise ratios from 57 dBA ~ 65 dBA
- Current consumption as low as 80 µA
- 300 Ω output impedance rating
- Top port and bottom port versions
more information: www.oemsecrets.com & www.digikey.com
Login
