![Over Current Protection Switch Over Current Protection Switch](https://www.electronics-lab.com/wp-content/uploads/2016/04/Current_Sense_Switch_IMG_4786-e1460369645558.jpg)
Current Sensing Switch is designed to operate a Relay Contact when there is a DC current through the sense resistor exceeds the set point, Set point adjustable from 1A to 3Amp using on board potentiometer. This circuit can offer over current protection to your project.
Specifications
- Input: 12 VDC
- Range: 1 to 3 A selectable with onboard preset
- Output: SPDT Relay (Normally Open & Normally Closed)
- Power Battery Terminal (PBT) and Terminal Pins for easy connection
- Four mounting holes of 3.2 mm each
- PCB dimensions 52 mm x 47 mm
Over Current Protection Switch – [Link]
Login
