The new DAQ970A System is Keysight’s next generation 3-slot mainframe Switch/Data Acquisition System with built-in 6 ½ digit DMM based on the best-selling TrueVolt DMM series. 8 switch and control plug-in modules are offered, among them a new 20-channel solid-state multiplexer that vastly increases scan speeds to up to 450 ch/s. The system measures and converts 12 different input signals, with built-in signal conditioning to minimize external wiring from having to use external or plug-in signal conditioning modules.
- Advanced 6½ digit internal DMM with improved accuracy and faster measurement speed
- Ability to measure very low current ranges (1 μA DC and 100 μA AC) and higher resistance range (1000 MΩ)
- New auto-calibration that compensates for internal drifts caused by time and temperature changes
- 3497XA compatible, program and configuration
Key Features & Specifications
- 3-slot mainframe with USB and LAN
- 6 1/2-digit (22-bit) internal DMM, scanning up to 450 channels per second with new solid-state multiplexer module
- 8 switch and control plug-in modules to choose from
- Built-in signal conditioning measures thermocouples, RTDs and thermistors, AC/DC volts and current; resistance, frequency/period, diode test and capacitance
- 100k readings of non-volatile memory holds data when power is removed
- Hi/LO alarm limits on each channel, plus 4 TTL alarm outputs
- BenchVue software enabled: BenchVue DAQ Control and Analysis app enables you to create tests without programming
Price for DAQ970A is ~£1.383 and more information is available on www.keysight.com
Download White Paper [via oemsecrets.com]: Practical steps in design verification using a DAQ data logger
Login
