![dbLoRa-X1 is a Arduino compatible battery operated LoRaWAN End Node dbLoRa-X1 is a Arduino compatible battery operated LoRaWAN End Node](https://www.electronics-lab.com/wp-content/uploads/2020/02/dbLoRa-X1-scaled-e1582098720900.jpg)
Arduino compatible battery-operated LoRaWAN End Node using the RFM95 with the ATMega328P microcontroller.
Requirements:
- Install the Arduino IDE
- Install MCCI LMIC library https://github.com/mcci-catena/arduino-lmic
- Inside the Arduino Libraries folder, Go to Arduino\libraries\MCCI_LoRaWAN_LMIC_library\project_config
- Choose your region and chip accordingly
- Example: For India 865 MH branch, select #define CFG_in866 1 & #define CFG_sx1276_radio 1
- Change the OTAA Keys
- Upload the program onto the board using a USB-UART converter
the project files are available on Github.com
Login
