DC Motor Direction Control project offers direction control using digital logic gates and a DPDT relay.
- Supply input 12 VDC @ 75 mA
- Power LED
- DC Motor Direction LED Yellow/Green
- Relay Output: up to 7 A
- Onboard tactile switch for direction control
- Relay based drive design with diode protection
- LED indicator for direction indication
- Power-On LED indicator
- Terminal pins and screw terminal connector for easy input / output connection
- Four mounting holes of 3.2 mm each
- PCB dimensions 41 mm x 81 mm
DC Motor Direction Controller with tact switches – [Link]
Login
