![DC2412-UPSP2 – DC/DC Supply with UPS function is Open Frame 60W / 16-32VDC / 12VDC / 5A / 480F Supercaps DC2412-UPSP2 – DC/DC Supply with UPS function is Open Frame 60W / 16-32VDC / 12VDC / 5A / 480F Supercaps](https://www.electronics-lab.com/wp-content/uploads/2022/03/DC2412-UPSP2_2.jpg)
Uninterruptible 12VDC power supply! Powerful DC UPS module with maintenance-free Supercaps and wide-range input 16… 32VDC The robust DC2412-UPSDP2 is a maintenance-free 12VDC emergency power supply in open frame design. To protect against voltage fluctuations, flicker, voltage drops or failures in the supply voltage, the DC UPS modules are equipped with Supercaps as energy storage devices that work on the principle of double-layer capacitors (EDLC).
Supercap DC UPS with wide-range input 16…32 VDC
- DC UPS with uninterruptible 12VDC output
- Maintenance-free supercaps for energy storage
- High cycle stability >500.000
- Charge time <60 sec at maximum charge current
- Extended temperature range -20…+70°C
- Active reverse polarity protection
- Power Fail signal via relay, RS232 connection
- Reboot Function
- 3 years warranty
more information: https://www.bicker.de/en/dc2412-upsp2
Login
