![DeskPi Super6C Raspberry Pi CM4 Cluster Mini-ITX board 6 RPI CM4 supported DeskPi Super6C Raspberry Pi CM4 Cluster Mini-ITX board 6 RPI CM4 supported](https://www.electronics-lab.com/wp-content/uploads/2022/08/raspberry-pi-cm4-cluster-mini-itx-board-6-rpi-cm4-supported_1_1024x1024@2x.jpg)
DeskPi Super6C is the Raspberry Pi cluster board a standard size mini-ITX board to be put in a case with up to 6 RPI CM4 Compute Modules.
Highlights
- DeskPi Super6C is the Raspberry Pi cluster board a standard size mini-ITX board to be put in a case with up to 6 RPI CM4 Compute Modules.
- 6 RPI CM4 supported 1 Gbps RJ45 x2
- Onboard ON/OFF and Reset button
- 12V FAN Header x3
- DC 19v~24V or ATX 12V
- Package Includes: 1 x Raspberry Pi CM4 Cluster Mini-ITX board, 1 x 100W Power Supply (Note:Raspberry Pi CM4 board are Not Included)
- PC Case front panel header
- 12V FAN Header x3
- Mini ITX Case supported
For every CM4
- M.2 2280 slot (PCIe Gen 2 x1)
- TF Card slot
- 5V FAN Header
- Micro USB 2.0
Only for 1st CM4
- USB Host A 2.0 x2
- USB Host 2.54 4-pins x2
- HDMI 2.0 x1
- HDMI 1.4a x1
52Pi sells the DeskPi Super6C on their website for $199.99 + shipping
more information: https://deskpi.com/collections/deskpi-super6c/products/deskpi-super6c-raspberry-pi-cm4-cluster-mini-itx-board-6-rpi-cm4-supported
Login
