DFI RPS101/RPS103 Mini-ITX Motherboard with Intel Core and R680E/Q670E/H610E Chipsets for Automation and Kiosk Applications
1.055
The DFI RPS101/RPS103 is a Mini-ITX industrial motherboard designed specifically for automation and kiosk applications. It supports Intel Core processors from the 12th to the 14th generation, making it suitable for real-time processing in industrial environments. With a compact form factor, the motherboard still allows high performance, supporting up to 64GB of DDR5 memory at 5600MHz, which is essential for handling data-intensive tasks in smart factories.
DFI RPS101/RPS103 mini-ITX
For scalability, the RPS101/RPS103 includes a PCIe x16 Gen 5 slot, enabling users to add AI processing units or other specialized industrial modules without changing the motherboard. This feature, along with its robust processing capabilities, makes the RPS101/RPS103 a versatile choice for factory automation and other industrial applications that require reliable, high-speed computing.
We’ve previously covered various Mini-ITX motherboards, including the Turing Pi 2.5, MI1001, ASUS N97T-IM-A, MI1002, and ASRock IMB-A8000. Feel free to explore those articles if you’re interested in similar products.
DFI RPS101/RPS103 front view
The DFI RPS101/RPS103 mini-ITX motherboard specifications:
  • Processor:
    • 14th Generation Intel LGA 1700 Socket Processors, TDP support up to 65W
    • 13th Generation Intel LGA 1700 Socket Processors, TDP support up to 65W
    • 12th Generation Intel LGA 1700 Socket Processors, TDP support up to 65W
  • GPU:
    • Intel UHD Graphics 700 series (3D graphics HW acceleration:DX12, Open GL 4.6, Vulkan 1.2)
    • Hardware Decode – HEVC/H.265, AVC/H.264, VP9, VP8, JPEG/MJPEG
    • Hardware Encode – HEVC/H.265, AVC/H.264, JPEG, VP9, VP8
  • Chipset: Intel R680E/Q670E/H610E
  • Memory:
    • Two 262-pin SODIMM up to 64GB
    • Dual Channel DDR5 5600 MHz
  • BIOS: AMI SPI 256Mbit
  • Storage:
    • 2x SATA 3.0, up to 6Gb/s
    • 1x M.2 2242/3042/3052 B-Key
      • R680E/Q670E: PCIe 3.0 x1, SATA 3.0 x1, USB 3.2 Gen 2 x1, USB 2.0 x1
      • H610E: PCIe 3.0 x1, SATA 3.0 x1, USB 3.2 Gen 1 x1, USB 2.0 x1
      • 1x M.2 2280 M-Key
        • R680E/Q670E: PCIe 4.0 x4 or SATA 3.0 x1
        • H610E: PCIe 3.0 x1 or SATA 3.0 x1
      • Additional Slots (R680E/Q670E)
        • M.2 2230 E-Key: USB 2.0 x1, CNVio, PCIe 3.0 x1
  • Video Output:
    • Quad Display Support
      • HDMI 2.0: 4096×2160 @ 60Hz
      • DP++ 1.2: 4096×2160 @ 60Hz
      • USB Type-C (H610E not supported): 4096×2304 @ 60Hz
      • eDP: 4096×2160 @ 60Hz
      • LVDS: 1920×1200 @ 60Hz
    • DFI Display Extension Port
  • Audio:
    • Realtek ALC888 High-Definition Audio (Line-out jack, Mic-in jack)
  • Networking: 2x 2.5GbE (RJ-45) connectors
    • 1x Intel I226-LM (supports iAMT with Core i9/i7/i5)
    • 1x Intel I226-V or 2x Intel I226-V (H610E chipset only)
  • USB:
    • Rear I/O
      • R680E/Q670E Chipsets
        • 5x USB 3.2 Gen 2 Type-A
        • 1x USB 3.2 Gen 2 Type-C
      • H610E Chipset
        • 2x USB 3.2 Gen 2
        • 1x USB 3.2 Gen 1
        • 2x USB 2.0
    • Internal I/O
        • 4x USB 2.0 (via 2×5 2.0mm pitch headers)
      • H610E Chipset
        • 2x USB 2.0 (via 1×5 2.0mm pitch header)
  • Serial: 2x RS-232/422/485 ports (via box headers, 2.0mm pitch)
  • Security: Nuvoton TPM 2.0
  • Expansion:
    • PCIe x16 Gen5 slot
    • 8-bit DIO (Digital Input/Output)
    • SMBus
  • Misc:
    • System Reset
    • RTC (Real-Time Clock)
  • Power supply
    • 12V +/-10% via DC Jack for RPS101
    • Wide Range 12~28V via DC jack for RPS103
    • DC-in connector right angle and straight available upon request
  • Dimensions: 170 x 170 mm (Mini-ITX form factor)
  • Temperature Range:
    • Operating: -5°C to 65°C
    • Storage: -40°C to 85°C
  • Humidity:
    • Operating: 5% to 90% RH
    • Storage: 5% to 90% RH
  • Certificate: CE, FCC Class B, RoHS
The RPS101/RPS103 Mini-ITX motherboard offers robust connectivity, supporting up to four independent 4K displays—ideal for detailed factory monitoring and interactive kiosk applications. Its extensive I/O options facilitate smooth integration with sensors, controllers, and peripherals, enhancing industrial workflows. Key features include dual Intel 2.5GbE ports, six USB 3.2 Gen 2 ports, two COM ports, and two SATA 3.0 connectors, enabling efficient data collection, streamlined operations, and adaptable self-service solutions suited for both industrial settings and kiosk deployments.
DFI RPS101/RPS103 block diagram
The RPS101/RPS103 Mini-ITX motherboard supports Windows 10 IoT Enterprise 64-bit, Windows 11 Enterprise, and Linux. Pricing information for the RPS101/RPS103 motherboards is currently unavailable; for quotes, interested parties should contact the company directly. Further details, including a complete list of compatible CPUs, can be found on the product page and in the press release.
About Sayantan Nandy
view all posts by sayantan
