![DIY milliohmmeter DIY milliohmmeter](https://www.electronics-lab.com/wp-content/uploads/2015/10/cover-1024x879-1024x879.jpg)
by hwmakers.eu:
This is an example of a simple and cheap milliohmmeter that can be made by every maker. The core of the circuit are a current source (LT3092) and a current sense (INA225): a costant current flows through the milliohm resistor under test and the voltage at the current sense output gives the value of the resistor (V=R*I).
The milliohmmeter can be used as a stand alone instrument by adding a MCU with at least 10 bit ADC and a LCD display or it can be used togheter with a DMM.
DIY milliohmmeter – [Link]
Login
