![DRV8317 3-Phase PWM Motor Driver DRV8317 3-Phase PWM Motor Driver](https://www.electronics-lab.com/wp-content/uploads/2023/04/ree0036a.png)
Texas Instruments’ integrated MOSFET driver is suitable for driving 3-phase motors
Texas Instruments’ DRV8317 3-phase PWM motor driver provides three integrated MOSFET half-bridges for driving 3-phase brushless DC (BLDC) motors with 5 V, 9 V, 12 V, or 18 V DC rails or 2s to 4s batteries. The driver provides integrated 3-phase current sensing, eliminating the need for external sense resistors. The DRV8317 has an integrated LDO that provides a regulated 3.3 V rail that can deliver up to 80 mA for external loads such as microcontrollers (MCUs), logic circuits, hall sensors, and more. The configurable 6x or 3x PWM-control scheme can implement a sensored or sensorless field-oriented control (FOC), sinusoidal control, or trapezoidal control using an external MCU.
The DRV8317 can drive a PWM frequency of up to 200 kHz and is highly configurable through the SPI (DRV8317S) or pins (DRV8317H). The configurable features include PWM mode, slew rate, current-sense gain, and more. The integrated protection features include supply undervoltage lockout (UVLO), overvoltage protection (OVP), charge-pump undervoltage (CPUV), overcurrent protection (OCP), overtemperature warning (OTW), overtemperature shutdown (OTS), and protects the device, motor, and the system against fault events which are indicated by the nFAULT pin.
- 3-phase BLDC motor driver:
- Configurable slew rate for EMI mitigation
- Programmable gain current sensing
- Supported PWM frequency: up to 200 kHz
- Integrated shoot-through protection
- Operating voltage range: 4.5 V to 20 V (24 V abs. max.)
- High output current capability: 5 A peak-current drive
- Low on-state resistance MOSFETs: RDS(ON) (HS + LS) at TA = +25°C : 130 mΩ (typ.)
- Ultra-low Q-current sleep mode: 3 µA (max.) at VVM = 12 V, TA = +25°C
- Built-in 3.3 V ±4.5%, 80 mA LDO regulator
- Multiple control interface options: 6x PWM and 3x PWM
- Integrated current sensing:
- No external current-sense resistor is required
- 3-phase current sense outputs
- SPI and hardware device variants:
- 10 MHz SPI interface variant for flexibility
- Pin-configurable variant for simplicity
- Supported logic inputs: 1.8 V, 3.3 V, and 5 V
- Integrated protection features:
- VM UVLO, VM OVP, CPUV, OCP, and OTW/OTS
- Fault-condition indication pin (nFAULT)
more information: https://www.ti.com/product/DRV8317
