![DSO-1000E/F Series – Four-channel oscilloscopes with bandwidth up to 250MHz DSO-1000E/F Series – Four-channel oscilloscopes with bandwidth up to 250MHz](https://www.electronics-lab.com/wp-content/uploads/2018/04/voltcraft-e1524832431965.jpg)
Conrad Business Supplies, a household name for the distribution of electronics items has added to its ever-expanding products a new set of Oscilloscopes made by Voltcraft. The oscilloscopes are four-channel, they are very well equipped and are particularly suitable for measurements in research and development departments, in laboratories and schools as well as for maintenance, repair and service tasks.
DSO1000E/F Series of oscilloscopes cover the bandwidths from 80MHz to 200MHz and provide the real-time up to 1GSa/s. Also, they have 7-inch color TFT LCD with a resolution of 800 x 480 pixels as well as Windows-style interface and menus for smooth operation. What’s more, the plenty menu information and the easy-to-operate buttons allow you to gain information as much as possible while measuring; the multifunctional knobs and the powerful shortcut keys help you save a lot of time in operation; the Auto Scale function lets you detect sine and square waves automatically. By using the three methods the oscilloscope provides (context-sensitive, hyperlinks, and an index), you may master all operations on the device in quite a short time so as to greatly improve your efficiency in production and development.
The digital oscilloscope is intended to be used for visualizing electrical magnitudes and signals. There are four independent input channels available for measurement. The measuring lead is connected to the oscilloscope via two BNC sockets. Integrated help system can be called upon the display. The signals measured can be displayed on display as well as on a PC when a USB cable is used. The oscilloscopes also have a USB interface for connecting an additional data memory, for example, a USB stick.
The Oscilloscopes can perform some of the following: FFT (Fast Fourier Transform), extensive trigger options, standard Oscilloscopes functionality, firmware loading from a USB stick, and many more. The available models of the oscilloscopes are listed below:
- Model DA0-1084E :
- 4 Channels
- Bandwidth – 80MHz
- Sample Rate – 1GS/s
- Model DA0-1104E :
- 4 Channels
- Bandwidth – 100MHz
- Model DA0-1204E :
- 4 Channels
- Bandwidth – 200MHz
- Model DA0-1254E :
- 4 Channels
- Bandwidth – 250MHz
The oscilloscopes are available for purchase on Conrad with ranging price depending on the model.
