DTMF Module
DTMF Module
DTMF Development Board offers a very convenient way to generate DTMF tones and demodulate it.  It uses the famous MT8880/MT8888 DTMF transreceiver IC.
  • Easy 10 pin Box Header connector for interfacing data/control pins
  • Crystal derived frequency source for accurate generation and demodulation of DTMF tones for your project
  • Onboard upto 350 mW audio amplifier block for DTMF tones with Volume Adjust Preset
  • 5V Supply sourced via interfacing Box Header
  • Header  type analog connection
  • Four mounting holes 3.2 mm each
  • PCB dimensions 56 mm x 49 mm
DTMF Module – [Link]
