![Dual 90V/10A Unregulated Power Supply Dual 90V/10A Unregulated Power Supply](https://www.electronics-lab.com/wp-content/uploads/2016/08/IMG_1139.jpg)
This project is designed to provide symmetrical output unregulated, high voltage, high current for your demanding needs. Right choice for Audio Amplifiers, Power Drivers, Motor Drivers etc
- Input – maximum 65 VAC center-tap, 10Amp
- Symmetrical unregulated, individually fused outputs
- 10A bridge rectifier on board
- LED indication for both the outputs
- PCB mounted LUGS for connecting of input and output
- Four mounting holes of 3.2 mm each
- PCB Dimensions 154 mm x 84 mm
Dual 90V/10A Unregulated Power Supply – [Link]
Login
