![Dual-Channel Quadrature Hall-Effect Bipolar Switch Module for Magnetic Encoder Dual-Channel Quadrature Hall-Effect Bipolar Switch Module for Magnetic Encoder](https://www.electronics-lab.com/wp-content/uploads/2017/01/Hall-Effect-Bipolar-Switch-PIC1.jpg)
The A1230 is a dual-channel, bipolar switch with two Hall-effect sensing elements, each providing a separate digital output for speed and direction signal processing capability. The Hall elements are photo lithographically aligned to better than 1 µm. maintaining accurate mechanical location between the two active Hall elements eliminates the major manufacturing hurdle encountered in fine-pitch detection applications. The A1230 is a highly sensitive, temperature stable magnetic sensing device ideal for use in ring magnet based, speed and direction systems located in harsh automotive and industrial environments.
The A1230 monolithic integrated circuit (IC) contains two independent Hall-effect bipolar switches located 1 mm apart. The digital outputs are out of phase so that the outputs are in quadrature when interfaced with the proper ring magnet design. This allows easy processing of speed and direction signals. Extremely low-drift amplifiers guarantee symmetry between the switches to maintain signal quadrature. The Allegro patented, high-frequency chopper-stabilization technique cancels offsets in each channel providing stable operation over the full specified temperature and voltage ranges.
Dual-Channel Quadrature Hall-Effect Bipolar Switch Module for Magnetic Encoder – [Link]
