![Dual Motor L298 H-Bridge Motor Control Dual Motor L298 H-Bridge Motor Control](https://www.electronics-lab.com/wp-content/uploads/2015/12/IMG.png)
Dual Motor L298 H-Bridge Control project can control two DC motors connected to it. The circuit has been designed around popular dual H-Bridge L298 from ST. This circuit has current sense resistors for both H-bridges to provide voltage which enables this board to use in stepper motor applications.
Specifications
- Motor supply : 7 to 46 VDC
- Control Logic Supply : Standard TTL logic level
- Output DC drive to motor : up to 2 A each
- Current Sense Output available
- Enable and direction control pins available
- External diode bridge for protection
- Heat-sink for IC
- Power-On LED indicator
- Screw terminal connector for easy input supply (PWR) / output (Motor) connection
- Four mounting holes of 3.2 mm each
- PCB dimensions 61 mm x 63 mm
Dual Motor L298 H-Bridge Motor Control – [Link]
Login
