![A dual sensor fan controller build A dual sensor fan controller build](https://www.electronics-lab.com/wp-content/uploads/2016/10/pic-board2.jpg)
Kerry Wong has designed and built a dual sensor fan controller:
To make the design more useful, one channel is marked as optional (see components with * on the silkscreen) so that you can build either a single sensor fan controller or a dual sensor one. With two sensors, the control signal is or’d with both of the sensor input and if either side of the temperature exceeds a predefined threshold the fan will be turned on. This is useful in situations where power devices from multiple channels share the same heat sink
A dual sensor fan controller build – [Link]
Login
