![Dynamic-load circuit determines a battery’s internal resistance Dynamic-load circuit determines a battery’s internal resistance](https://www.electronics-lab.com/wp-content/uploads/2016/06/internal_resistance_measure-e1466781734890.png)
by Jim Williams @ end.com
The simplest model of a battery comprises an ideal voltage source that connects in series with a resistance whose value—often a few milliohms—depends on the battery’s electrochemical condition and construction. If you attempt to use an ordinary ac milliohmmeter containing a kilohertz-range ac excitation source to measure a battery’s internal resistance, you get erroneous results due to capacitive effects, which introduce losses. A more realistic battery model includes a resistive divider that a capacitor partially shunts (Figure 1). In addition, a battery’s no-load internal resistances may differ significantly from their values under a full load. Thus, for greatest accuracy, you must measure internal resistance under full load at or near dc.
Dynamic-load circuit determines a battery’s internal resistance – [Link]
