![EA uniTFs035-ATC Mini Touch Panel EA uniTFs035-ATC Mini Touch Panel](https://www.electronics-lab.com/wp-content/uploads/2021/04/EA-UNITFTS035-ATC-Display-Visions-Optoelectronics-DigiKey-e1618229654100.png)
EA Display Visions’ 3.5″ intelligent EA uniTFTs035-ATC display module is an all-in-one implementation of the display, microcontroller unit, and touchscreen. The module includes everything needed to directly control an application and expedite the development, prototyping, and deployment of an HMI/GUI. Design an HMI/GUI using the easy-to-use drag-and-drop uniTFT DESIGNER graphics development software and simple ASCII text-based instructions. Thanks to the integrated input/output and fast graphics controller, the display modules are ready to run without additional peripherals. They can be controlled via USB, SPI, I²C, and RS232. The IPS panels with all-angle color stability (AACS) technology keep contrast and colors stable even at oblique viewing angles. These displays are not subject to the inverse tilt effect that is inherent in the widely used TN displays. With a maximum brightness of more than 1,000 cd/m², they are readable even in direct sunlight or under bright surgical lights. The capacitive touch surface of the uniTFT recognizes multi-finger gestures and reacts reliably when used with thin gloves.
Contents
- 3.5″ integrated capacitive touch intelligent display module
- uniTFT DESIGNER (graphics software, download under Tools)
- 3.5″ IPS TFT 480×320
- Included PCAP touch panel optically bonded
- Free, easy-to-use uniTFT DESIGNER graphics development software
- AACS-display (all-angle color stability, optimized backlight, and IPS TFT-panel over widest viewing angle)
- Super-bright LED backlight over 800 cd/m²
- Object-oriented screen layout
- Change object during runtime: size, shape, color, and content
- Animate and move objects
- Alpha-blending
- Single supply 3.3 V or directly through USB
- Fonts: ASCII and Unicode
- Serial interfaces: USB, RS232, SPI, and I²C
- Eight digital, freely definable I/Os built-in, expandable up to 136
- Four analog inputs
- Time (RTC), battery-buffered
- Flash memory as storage for pictures, fonts, menus, and log files
- Internal functions for calculation as well as programmability
- Speaker for tone feedback built-in
- RoHS, REACH, and CE compliant
- Temperature range: -20°C to +70°C
- Waterproof mounting
more information: https://www.displayvisions.us
