![Easy Planter – A Simple Way Of Monitoring Plants Easy Planter – A Simple Way Of Monitoring Plants](https://www.electronics-lab.com/wp-content/uploads/2016/07/easyplanter.png)
Easy Planter is a plant monitoring device able to sense temperature, humidity, pressure, moisture, light etc.
A small bluetooth low energy plant sensor that easily fits into a plant pot. It can monitor temperature, humidity, pressure, moisture, light, and has I2C extension pins so that you can add other modules. Information is sent to a phone, and notifies you when it needs something.
Easy Planter – A Simple Way Of Monitoring Plants – [Link]
And if you are familiar with a soldering iron, you can even automate the watering. I made a working prototype here, based on the Particle Core (www.particle.io) : https://github.com/yerpj/SmartWatering
Thanks for pointing me to your plant watering project. I feature it on the blog. Hope you like it!
Thanks for the post!
