![ECS ECS-RTC-3225-5699HS Real Time Clock Module ECS ECS-RTC-3225-5699HS Real Time Clock Module](https://www.electronics-lab.com/wp-content/uploads/2021/09/index.jpg)
ECS ECS-RTC-3225-5699HS Real Time Clock Module (RTC) features an I2C bus and a built-in 32.768KHz temperature-compensated TCXO. The ECS ECS-RTC-3225-5699HS supports calendar (year, month, day, hour, minute, and second), clock, and timer functions. ECS ECS-RTC-3225-5699HS features a 2.5V to 5V power supply voltage along with a 1.6V to 5V backup battery. This RTC operates over a -40°C to +85°C operating temperature range.
- RTC with built-in 32.768KHz TCXO
- Supports calendar, clock, and timer functions
- I2C bus
- Low-frequency resonator
- RoHS compliant
Specifications
- 2.5V to 5V power supply voltage (normal mode)
- 3V typical power supply voltage
- 1.6V to 5V backup battery
- 0.5μA current consumption
- ±3ppm aging per year
- -40°C to +85°C operating temperature range
Block Diagram
more information: https://ecsxtal.com/store/pdf/ECS-RTC-3225-5699HS.pdf
Login
