![EDATEC ED-IPC3020 is A Fanless RPi 5 PC with M.2 SSD and RS485/RS232 Interfaces EDATEC ED-IPC3020 is A Fanless RPi 5 PC with M.2 SSD and RS485/RS232 Interfaces](https://www.electronics-lab.com/wp-content/uploads/2023/12/Screenshot-2023-12-29-at-08-14-45-S1b91c737c061475799e8357c33f240ca9.jpg-WEBP-Image-960-×-6682-pixels.jpg)
The EDATEC ED-IPC3020 is a fanless PC based on the Raspberry Pi 5. It stands out because it supports NVMe M.2 SSD and features RS232 and RS485 serial ports. It also offers the standard I/O capabilities of the Raspberry Pi 5.
The new Raspberry Pi 5 SBC has a PCIe 2.0×1 interface that lets you connect various devices, like SSDs. Companies like PineBerry Pi have used this feature to create add-ons like the PineBerry Pi HatDrive. Now, with the EDATEC series, we get a full Raspberry Pi 5 computer that includes M.2 NVMe storage.
The fanless industrial PC integrates the Raspberry Pi 5 with accessible ports and an add-on board for M.2 NVMe, serial ports, RTC battery, and buzzer. It also includes speaker and 5V output connectors for potential future use with a Raspberry Pi 5 smart display.
EDATEC’s ED-IPC3020 supports all Raspberry Pi OS variants and includes scripts for drivers and configuration to enable additional features. Its design features a thermal pad for cooling and an M.2 SSD connected to the Pi 5 via GPIO and PCIe.
EDATEC ED-IPC3020 specifications(Mostly RPI-5 Specs):
- SoC:
- Broadcom BCM2712 quad-core Arm Cortex-A76 processor, up to 2.4 GHz
- VideoCore VI GPU
- 4Kp60 H.265 decoder
- Memory:
- Options: 4GB or 8GB LPDDR4X-4267 SDRAM
- Storage:
- MicroSD card slot for the OS
- M.2 Key-M PCIe socket for 2230, 2242, or 2260 NVMe SSD (can also boot OS)
- Video Output:
- 2x micro HDMI ports, up to 4Kp60
- Networking:
- Gigabit Ethernet RJ45 port (optional PoE support)
- Dual-band 802.11ac Wi-Fi 5
- Bluetooth 5.0 Classic and BLE
- USB Ports:
- 2x USB 2.0 Type-A (up to 480Mbps)
- 2x USB 3.0 Type-A (up to 5Gbps)
- Audio:
- 3.5mm stereo audio output jack (green)
- 3.5mm stereo audio LINE IN jack (red)
- Serial Ports:
- RS485 via 3-pole Phoenix terminal with 120Ω terminal resistor
- RS232 via 3-pole Phoenix terminal
- Expansion I/Os (internal only, not usable with ED-IPC3020 enclosure):
- 3-pin 5V/1A DC OUT 2.0mm pitch WTB connector (extended LCD)
- 4-pin speaker 1.5mm pitch WTB connector (dual channel stereo audio output)
- 2x MIPI CSI/DSI connectors (extended LCD screen, supporting I2C touchscreen and backlight adjustment)
- Miscellaneous:
- Power button
- Power LED, ACT LED, 2x green UART LEDs (COM1 and COM2)
- RTC with SuperCAP and CR1220 battery backup
- Buzzer (alarm for bad configuration)
- Power Supply:
- 5V DC/5A via USB-C port
- Power Consumption: 25 Watts (Max)
- Physical Specifications:
- Dimensions: 102.8 x 89.5 x 32.5mm
- Weight: 300 grams
- Temperature Range: Operating: -25°C ~ 60°C; Storage: -25°C ~ 60°C
- Humidity: 5% ~ 95% (non-condensing)
- Certifications:
- FCC 47 CFR Part 15 Subpart B
- Various EN IEC standards (62368-1, 62311, 61000-3-2, 61000-3-3, 55032, 55035)
- Various EN 301 standards (489-1, 489-3, 489-17, 489-52, 328, 440, 511, 908-1, 908-2)
EDATEC’s ED-IPC3020 starts shipping in January, with pre-orders on Aliexpress ranging from $165 to $243, based on RAM (4GB/8GB) and storage options (microSD or 128GB/256GB SSD).
In this video Randall Restle explains the “industrial” aspect of the EADTEC ED-IPC3020:
https://youtu.be/Tla4oRwIdCk&t=214
Now that I’ve got hands on the ED-IPC3020, it appears to be a well built and rather complete RPi-5 solution that includes M.2 PCIe NVMe SSD, Audio I/O and even a buzzer all within a fan-less metal case; these are things that would have to be purchased additionally to a bare RPi-5. So, I feel it is priced competitively.
However, I’m finding the lack of documentation, other than this datasheet: https://edatec.cn/uploads/soft/240119/IPC3020datasheet-en.pdfhttps://edatec.cn/uploads/soft/240119/IPC3020datasheet-en.pdf, frustrating, and the lack of a support forum leaves me without specifics regarding, for instance, how to use the buzzer. Perhaps, when I find time to open the case, some of these issues will resolve themselves. Also, the metal case appears to function well as a Faraday cage effectively disabling the RPi-5 on-board WiFi. Of course, this is easily overcome by inserting a USB WiFi adapter.
So far, the EDATEC ED-IPC3020 feels like a valuable addition to the RPi-5 marketplace.
Best regards
Larry
