As mentioned earlier, the Mercury+ XU6 system on module is powered by the Xilinx Zynq Ultrascale+ MPSoC that features ARM dual-/quad-core Cortex-A53 clocked up to 1333 MHz and ARM dual-core Cortex-R5 running at a clock speed of 533 MHz. The system on module is integrated with up to 8GB DDR4 ECC SDRAM, 16GB eMMC flash, and 64MB QSPI flash storage.
Features of Mercury+ XU6 System on Module:
- CPU: Xilinx’s Zynq Ultrascale+ MPSoC with ARM dual-/quad-core Cortex-A53 (64 bit, up to 1333 MHz) ARM dual-core Cortex-R5 (32 bit, up to 533 MHz)
- GPU: Mali-400MP2
- RAM: 8 GB DDR4 ECC SDRAM
- Flash memory: 16 GB eMMC flash, 64 MB QSPI flash
- Interfaces: PCIe Gen3 x4, PCIe Gen2 x4, 2x USB 3.0 and Gigabit Ethernet interfaces
- Dimension: 65 × 54 mm
- Power supply: 5–15 V supply
When we talk about any system on module, it requires a carrier board where it can be plugged or soldered. The manufacturer comes with two baseboards that support Mercury+ modules. The first Mercury+ PE1 has IO interfaces for almost every application and has three variants for building custom FPGA and SoC-based hardware.
The Mercury+ ST1 carrier board is designed for rapid prototyping and for building FPGA systems. For those looking to buy the Mercury+ XU6 module for the video codec and implement it in a video-based application, this Mercury+ ST1 baseboard is well suited for such applications due to its wide range of I/O interfaces.
Enclustra also unveiled the Andromeda XZU90 SoM, but it is still under development and is designed for high-end applications. For a single unit, the Mercury+ XU6 is priced in the range of $299.00 to $1134.00, depending on the variant. More details on the hardware specifications are available on the official product page.
