![Engicam Launches Compact STM32 Based SOM for Secure IoT Applications Engicam Launches Compact STM32 Based SOM for Secure IoT Applications](https://www.electronics-lab.com/wp-content/uploads/2023/07/micro-som.jpg)
MicroGEA is an STM32-based compact System-on-Module (SoM) from Engicam. It is designed with the latest STM32MP135 microprocessors with Arm Cortex-A7 compute core. It also features a dedicated LCD-TFT display interface, a 16-bit parallel camera interface, and dual Ethernet ports. MicroGEA boards are designed for various applications like industrial automation, IoT, wearables, and embedded computing.
The STM32MP135 is a 1GHz 32-bit Arm Cortex-A7 processor with 32Kb L1 and 128Kb L2 cache. Referencing the STM32MP135 datasheet, it has two ADCs, ten 16-bit timers, two 32-bit timers, two PWM timers, a random number generator, a low-power RTC, and a secured cryptographic cell. Additionally, it supports security features such as TrustZone peripherals and tamper pins.
Besides that, this micro has an LCD-TFT controller with 4-bit color depth and a WXGA resolution of 1366 × 768 at 60 FPS. The STM32MP135 microcontroller also has a watchdog timer, a cryptographic engine, and a random number generation. Additionally, it supports CoreSight trace and debug capabilities. Coupled with 3072-bit fuses, including a unique ID, it forms a comprehensive solution for wearables and low-power applications.
Talking about supported protocols, this controller includes 2x SPI, 4x UART, 2x USART, 2x CAN, 2x I2C, 2x Analog, 2x SD/MMC, and multiple GPIOs.
Key Features and Specifications of STM32MP135 Microcontroller
Here are all the features of the STM32MP135 microcontroller; for more details, you can check out the device’s datasheet.
- The processor core is a 32-bit Arm Cortex-A7 with 32-Kbyte L1 cache, 128-Kbyte L2 cache, NEON, and TrustZone.
- Regarding memory, it supports up to 1GB external LPDDR3L RAM, 168KB internal SRAM, dual Quad-SPI, and an external memory controller.
- Safety features include TrustZone peripherals, 12 tamper pins, temperature, voltage, and frequency monitoring.
- Power management features include 1.71V to 3.6V I/Os, on-chip LDOs, a backup regulator, internal temperature sensors, and more.
- Regarding oscillator support, it has Internal and external oscillators and 4 PLLs.
- This controller supports up to 135 secure I/O ports with interrupt capability.
- In terms of communication, it has 5x I2C, 4x UART + 4x USART, 5x SPI, 2x SAI, SPDIF Rx, 2x SDMMC, 2x CAN, 2x USB 2.0, 2x Ethernet MAC/GMAC, 8-16 bit camera interface.
- This device has 2x ADCs, a temperature sensor, DFSDM, two bus matrices, and 4 DMA controllers.
- Regarding graphics, it has a built-in LCD-TFT controller up to WXGA (1366 × 768) @60 fps.
- This device supports 24 timers and two watchdog timers.
- Debug capabilities include Arm CoreSight trace and debug and a 4-Kbyte embedded trace buffer.
- Other notable features include 3072-bit fuses with a 96-bit unique ID and ECOPACK2-compliant packaging.
Operating on Linux and Yocto, the module is industrially qualified to withstand harsh environments, as noted on the product page. However, Engicam hasn’t disclosed the price for this device.
For more technical details, see the MicroGEA STM32MP13 product page.
