![EPC9160 Synchronous Buck Converter Reference Design EPC9160 Synchronous Buck Converter Reference Design](https://www.electronics-lab.com/wp-content/uploads/2022/03/epc-epc9160-synchronous-buck-converter-reference-design-lrg-a.png)
EPC’s EPC9160 9 V to 24 V to dual output 5 V/3.3 V synchronous buck converter reference design
EPC’s EPC9160 is a 9 V to 24 V to dual output 5 V/3.3 V, 15 A synchronous buck converter operating at 2 MHz switching frequency. The EPC9160 features the EPC2055 GaN FET and LTC7890 two-phase analog buck controller with integrated gate drivers from Analog Devices.
The efficiency of the EPC9160 is greater than 93% for 5 V output and 24 V input and, thanks to the high switching frequency, the converter size is very small at only 23 mm x 22 mm for both outputs and an inductor height of only 3 mm.
Applications
- Synchronous buck DC/DC converters
- Automotive consoles
- Power systems require a small size and very thin profile: computing, industrial, consumer, and telecom power
more information: https://epc-co.com/epc/Products/DemoBoards/EPC9160.aspx
Login
