![ESP32-Based FluidNC TMC2209 CNC Controller runs FluidNC open-source firmware ESP32-Based FluidNC TMC2209 CNC Controller runs FluidNC open-source firmware](https://www.electronics-lab.com/wp-content/uploads/2024/06/unnamed-e1719225646803.jpg)
FluidNC TMC2209 Pen/Laser CNC Controller is an ESP32-based 2-axis CNC controller with FluidNC firmware. This CNC controller is designed for machines that use stepper motors on 2 axes. These include pen drawing machines, laser cutters/engravers, sand plotters, etc. It also has an RC Servo connector for pen lift on a Z axis.
ESP32 wireless modules have been used for years in 3D printers and CNC controllers, such boards as Phi Mainboard 5LC 3D printer controller, Pen/Laser Engraver ESP32 Controller, Longer RAY5 Laser Engraver. Feel free to check those out if you are interested in those topics.
![](https://www.electronics-lab.com/wp-content/uploads/2024/06/unnamed-e1718975336261.png)
FluidNC TMC2209 Pen/Laser CNC Controller specifications:
- Wireless module: Espressif Systems ESP32-WROOM-32E
- Xtensa dual-core 32-bit LX6 microprocessor, up to 240 MHz
- 4MB flash
- 448 KB ROM, 520 KB SRAM and 16 KB SRAM in RTC
- 2.4 GHz WiFi and Bluetooth LE connectivity, built-in PCB antenna
- Stepper drivers: 2 numbers TMC2209 stepper drivers
- USB: USB type C port
- Interface: MicroSD card socket
- Misc:
- Optional stallGuard for sensorless end stops
- 1 number RC servo connection
- 6 numbers of inputs for limit and control switches
- I/O Expansion port for displays and pendants
- 3 numbers of 5V outputs to control lasers and accessories
- Power:
- input voltage (VIN) range 12-30 VDC
- Input current is minimum 3A
- Dimensions: 70mm x 70mm
You will find more technical details, a YAML file configuration, and setup information on the wiki page. The FluidNC source code is on GitHub. You can use a FluidNC web installer in Chrome, Edge, or Opera to install the firmware on compatible boards. The PCB design is open-source, and all resources are available in oshwlab. The 3D design of this board is available and you can download it from Fusion360.
![](https://www.electronics-lab.com/wp-content/uploads/2024/06/0f6645864e1865c1c120f066fa023e18f6cb21dd.png)
The FluidNC TMC2209 Pen/Laser CNC Controller is now available to order on Tindie at $45 without shipping charges. It is also available on Elecrow at $40 or even lower if you buy two or more. If you need more than this CNC controller for your project, check out FluidNC’s wiki for a wide range of supported hardware options.
