ESP32-C6 is A 1.47-inch display development board with Wi-Fi 6 and Bluetooth
1.132
Waveshare has recently introduced the ESP32-C6, a Display Development Board, a microcontroller with a 1.47-inch 172×320 resolution LCD, featuring 262K colors. It is powered by a 160MHz single-core 32-bit RISC-V processor, with an additional low-power 20MHz processor. The board supports Wi-Fi 6 (802.11 b/g/n) and Bluetooth BLE 5, making it ideal for AIoT (Artificial Intelligence of Things) applications. It integrates 4MB Flash memory, 320KB ROM, and 512KB high-power SRAM. Additionally, it has a TF card slot for external storage, multiple IO interfaces for peripheral expansion, an onboard RGB LED, and a ceramic antenna.
This board is suitable for quickly developing HMI (Human-Machine Interface) systems and other ESP32-C6 applications, where low power consumption and high-performance AI computing are required. This board supports GUI programs like LVGL and is designed for various IoT scenarios with reliable security features and peripheral integration options.
Previously, we have written about some more interesting Development Boards like the Sparkfun Pro Micro-RP2350, the RDK X3 Development Board, Lilygo’s T-TWR REV2.1, and much more. Feel free to check those out if you are interested in the topic.
ESP32-C6 development board pinout
ESP32-C6 Display Development Board Pinout
ESP32-C6 development board Specifications:
  • Processor:
    • 32-bit RISC-V processor, up to 160 MHz
    • Low-power 32-bit RISC-V processor, up to 20 MHz
  • Memory:
    • 320KB ROM
    • 512KB high-performance SRAM
    • 16KB low-power SRAM
    • 4MB Flash
  • Display:
    • 1.47-inch LCD, 172×320 resolution, 262K colors
    • Supports LVGL GUI programs
  • Wireless Connectivity:
    • 2.4GHz Wi-Fi 6 (802.11 ax/b/g/n)
    • Bluetooth 5.0 (LE) & Bluetooth Mesh
  • Storage:
    • TF card slot for external storage
  • I/O Interfaces:
    • 13x GPIO header for peripheral expansion, UART, I2C, PWM
    • 6x ADC pin
    • 5V, 3.3V, GND
    • Full-speed USB port
  • Other ports and Buttons:
    • Built-in RGB LED
    • Onboard ceramic antenna
    • BOOT and RESET buttons
  • Power:
    •  5V via USB Type-C
    • Low dropout regulator, 800mA output (max)
  • USB:
    • 1x USB Type-C port for power, programming, and data
  • Operating Environment:
    • Suitable for AIoT applications
    • Multiple power modes for low power consumption
  • Dimensions:
    • 36.37 x 20.32mm (not including the USB port)
  • Software:
    • Supports GUI development with LVGL
    • Suitable for HMI and IoT projects
ESP32-C6 development board peripherals
1. ESP32-C6FH4, 2. ME6217C33M5G Low dropout regulator, 800mA output (Max.), 3. TF card slot, 4. Onboard ceramic antenna, 5. BOOT button, 6. RESET button
The ESP32-C6 1.47-inch Display Development Board weighs just 0.008 kg and comes with the ESP32-C6-LCD-1.47 development board along with a black header, making it a lightweight and compact solution for IoT and HMI projects.
This Board is available on Waveshare’s product page at $11.99.  It is also available on Aliexpress for $13.22 (additional shipping charge of $4.74). You have to visit its Wiki page to learn more about this product.
About Debashis Das
view all posts by das
