![ESP8266 LED Matrix Clock ESP8266 LED Matrix Clock](https://www.electronics-lab.com/wp-content/uploads/2018/07/F0UE4K2JJ4ZVT6Z.LARGE_.jpg)
Simple LED matrix Clock based on the popular ESP8266 with Real Time Clock module and time synchronization over WiFi from an NTP server.
One note on the RTC module, apparently it also has the ability to charge the battery, however that’s not a good idea when using a CR2032. One possible solution would be to cut the trace marked on the image in order to disable the charging part of the circuit.
ESP8266 LED Matrix Clock – [Link]
Login
