Espressif ESP32-H2-WROOM-07 is A Low Power RISC-V Based SoC for Bluetooth and Thread Connectivity
1.084
Espressif has unveiled the ESP32-H2-WROOM-07, a compact module that supports both Bluetooth Low Energy (BLE) and IEEE 802.15.4. Built on the ESP32-H2 series SoCs, it comes with a 32-bit RISC-V single-core processor clocked at up to 96 MHz. The module includes 128 KB of ROM, 320 KB of SRAM, and 4 KB of low-power memory, and offers either 2 MB or 4 MB of SPI flash storage.
ESP32-H2-WROOM-07
The ESP32-H2-WROOM-07 module has three GPIOs and supports multiple interfaces, including I2C, SPI, UART, and ADC. It features a built-in monopole antenna for wireless communication and operates within a 3.0–3.6 V voltage range and a temperature range of -40°C to 105°C. This module is designed for IoT projects such as smart homes, industrial automation, healthcare, and everyday electronics. It supports BLE 5.3 with mesh networking, works over long distances, and has built-in features for more functions. Low-power sensors, data loggers, smart farming, and robots often use it.
The module is compact, measuring 8.5 × 12.7 × 2.6 mm, and follows the IEEE 802.15.4-2015 standard, running at a 250 Kbps data rate in the 2.4 GHz band. It includes three strapping pins that double as GPIOs and comes with a built-in 32 MHz crystal oscillator. It also supports connectivity standards like Thread 1.3, Zigbee 3.0, and Matter, along with application-layer protocols like HomeKit and MQTT.
Previously, Espressif has showcased some ESP32-based products including the ESP32-C5 Test Board, the ESP32-C5 MCU, the ESP32-P4 SoC, and many more. Feel free to browse those, if you are interested in this topic.
ESP32-H2-WROOM-07 Specifications:
  • Chip: ESP32-H2 SoC
  • Architecture: 32-bit RISC-V single-core processor
  • Clock Speed: Up to 96 MHz
  • Memory:
    • 320 KB SRAM
    • 16 KB Cache
    • 128 KB ROM
    • 4 KB LP memory
  • Storage: 2 MB or 4 MB SPI Flash
  • Connectivity:
    • Bluetooth 5.3 (LE)
    • IEEE 802.15.4 (for Thread and Zigbee support)
  • Security:
    • ECC-based secure boot
    • AES-128/256-XTS flash encryption
    • ECDSA digital signature support
  • I/O:
    • 3x GPIOs/3x strapping pins
  • Interfaces:
    • ADC, ETM, PCNT, PARLIO
    • SPI, UART, I2C, I2S
    • RMT, GDMA, LED PWM
    • USB Serial/JTAG, TWAI, MCPWM
  • Misc:
    • 1x Monopole antenna
    • 32 MHz crystal oscillator
    • temperature sensor
    • general-purpose timers
    • system timer
    • watchdog timer
    • Supports 250 Kbps data rate in 2.4 GHz band and OQPSK PHY
  • Power: 3.0–3.6 V
  • Dimension: 8.5 × 12.7 × 2.6 mm
  • Temperature: –40∼105 °C
The module works with Espressif’s IoT Development Framework (ESP-IDF), so developers can use a platform trusted by millions of connected devices. Additionally, the ESP32-H2-WROOM-07 supports the ESP-Zigbee-SDK, allowing for the creation of reliable smart home automation devices.
ESP32-H2-WROOM-07
The ESP32-H2 series provides secure connections with features like ECC-based secure boot, AES-128/256-XTS flash encryption, ECDSA digital signatures, an HMAC peripheral for identity protection, and cryptographic accelerators for improved performance.
The ESP32-H2-WROOM-07 with 2 MB of Quad SPI flash is priced at $2.13, while the 4 MB version costs $2.17 on the ESP32 AliExpress store. More details, including the datasheet and ESP32-H2 DevKits, can be found on the company’s official website.
About Debashis Das
view all posts by das
