![Espressif Systems ESP32-C6-WROOM-1 Multiprotocol Modules Espressif Systems ESP32-C6-WROOM-1 Multiprotocol Modules](https://www.electronics-lab.com/wp-content/uploads/2023/02/149317726.png)
Espressif Systems ESP32-C6-WROOM-1 Multiprotocol Modules are general-purpose Wi-Fi®, IEEE 802.15.4, and Bluetooth® LE modules. These multiprotocol modules are built around the ESP32-C6 series of SoCs and 32-bit RISC-V single-core microprocessors featuring 4MB flash. The ESP32-C6-WROOM-1 multiprotocol modules feature 23 GPIOs, rich peripherals, and an onboard PCB antenna. These multiprotocol modules integrate a rich set of peripherals, including SPI, parallel IO interface, controller, and on-chip debugs functionality via JTAG and SOC event task matrix.
The ESP32-C6-WROOM-1 multiprotocol modules feature CPU and on-chip memory, WiFi, integrated components on the module, and Bluetooth. These multiprotocol modules operate at a 3V to 3.6V operating voltage range. The ESP32-C6-WROOM-1 multiprotocol modules are ideally used in smart homes, industrial automation, health care, and consumer electronics applications.
- Wi-Fi:
- IEEE 802.11ax-compliant:
- Beamformee that improves signal quality
- Channel Quality Indication (CQI)
- Dual Carrier Modulation (DCM) to improve link robustness
- Spatial reuse to maximize parallel transmissions
- Target Wake Time (TWT) that optimizes power-saving mechanisms
- Fully compatible with IEEE 802.11b/g/n protocol:
- Data rate up to 150Mbps
- Wi-Fi Multimedia (WMM)
- Immediate block ACK
- Fragmentation and defragmentation
- Transmit Opportunity (TXOP)
- Automatic Beacon Monitoring (Hardware TSF)
- 2412MHz to 2484MHz operating frequency range
- Bluetooth®:
- Multiple advertisement sets
- Advertising extensions
- High power mode (share the same PA with Wi-Fi)
- Peripherals
- Antennal options:
- On-board PCB antenna
- CPU and On-Chip memory:
- ESP32-C6 embedded, 32-bit RISC-V single-core microprocessor, up to 160MHz
- 320KB ROM
- 512KB SRAM
- 16KB Low-power (LP) SRAM
more information: https://www.espressif.com/en/products/socs/esp32-c6
