![Espressif Systems ESP32-H BLE & IEEE 802.15.4 Modules Espressif Systems ESP32-H BLE & IEEE 802.15.4 Modules](https://www.electronics-lab.com/wp-content/uploads/2023/05/189141014.png)
Espressif Systems ESP32-H BLE and IEEE 802.15.4 Modules are powerful, generic BLUETOOTH® Low Energy and IEEE 802.15.4 combo modules featuring the ESP32-H2 chip. The ESP32-H is suitable for building IoT applications with high requirements for power consumption.
The Espressif ESP32-H module is small-sized and pin-to-pin compatible with the ESP32-C3-MINI and ESP32-C6-MINI modules.
Block Diagram
- 32-bit RISC-V single-core processor that operates at up to 96MHz
- 19x programmable GPIOs, with support for UART, SPI, I2C, I2S, Remote Control Peripheral, LED PWM, Full-speed USB Serial/JTAG Controller, GDMA, and MCPWM
- Can be used for building Thread end devices, as well as Thread border routers and Matter bridges by combining it and an ESP Wi-Fi SoC
- 320KB SRAM, 128KB ROM, 4KB LP memory, and works with external flash
Specifications
- Embedded chips (ESP32-H2FH1, ESP32-H2FH2, and ESP32-H2FH4)
- 13.2mm × 16.6mm × 2.4mm Dimensions
- PCB antenna
- 1, 2, 4 Flash (MB)
- 5 Pins
more information: https://www.espressif.com/en/products/modules
test
