![Espressif Systems ESP32-S2-MINI-1 generic Wi-Fi MCU Espressif Systems ESP32-S2-MINI-1 generic Wi-Fi MCU](https://www.electronics-lab.com/wp-content/uploads/2020/12/EspressifSystemsESP32-S2-MINI-1.jpg)
ESP32-S2-MINI-1 is a powerful, generic Wi-Fi MCU module that has a rich set of peripherals
ESP32-S2-MINI-1 is a powerful, generic Wi-Fi MCU module that has a rich set of peripherals. This module is an ideal choice for a wide variety of application scenarios relating to the Internet of Things (IoT), wearable electronics, and smart home.
At the core of this module is ESP32-S2, an Xtensa® 32-bit LX7 CPU that operates at up to 240 MHz. ESP32-S2 integrates a rich set of peripherals, including SPI, I2S, UART, I2C, LED PWM, ADC, DAC, touch sensor, temperature sensor, and up to 43 GPIOs. It also includes a full-speed USB On-The-Go (OTG) interface to enable USB communication.
Key features
- Unparalleled security for your connected devices
- Helps you build connected low-power devices
- Build whatever you like with its rich IO capabilities
- Cost-effective
Additional features
- MCU
- Embedded ESP32-S2, with Xtensa® single-core 32-bit LX7 microprocessor, up to 240 MHz
- 128 KB ROM
- 320 KB SRAM
- 16 KB SRAM in RTC
- Hardware
- Interfaces: GPIO, SPI, LCD, UART, I2C, I2S, Camera interface, IR, pulse counter, LED PWM, USB OTG 1.1, ADC, DAC, touch sensor, temperature sensor
- 4 MB SPI flash
- Operating voltage/Power supply: from 3.0 to 3.6 V
- Operating temperature range: from -40 to 85 °C
- Wi-Fi
- 802.11 b/g/n
- Bit rate: 802.11n up to 150 Mbps
- 0.4 μs guard interval support
- Operating frequency range: from 2412 to 2484 MHz
more information: https://www.espressif.com/en/products/socs/esp32-s2
Login
