![Espressif Systems ESP32-WROOM-32E generic Wi-Fi+BT+Bluetooth LE MCU Espressif Systems ESP32-WROOM-32E generic Wi-Fi+BT+Bluetooth LE MCU](https://www.electronics-lab.com/wp-content/uploads/2020/10/EspressifSystemsESP32-WROOM-32E.jpg)
ESP32-WROOM-32E integrates ESP32-D0WD-V3 and has higher stability and security performance. It is a powerful, generic Wi-Fi+BT+BLE MCU module that targets a wide variety of applications, ranging from low-power sensor networks to the most demanding tasks, such as voice encoding, music streaming, and MP3 decoding.
Key features
- Extra security against Fault Injection Attacks
- Robust & Compact Design
- Ultra-low power consumption
- Optimized Layout
Additional features
- MCU:
- ESP32-WROOM-32E contains a dual-core Xtensa® 32-bit LX6 MCU.
- 448 KB of ROM for booting and core functions.
- 520 KB of on-chip SRAM for data and instructions.
- 8 KB of SRAM in RTC, which is called RTC FAST Memory and can be used for data storage; it is accessed by the main CPU during RTC Boot from the Deep-sleep mode.
- 8 KB of SRAM in RTC, which is called RTC SLOW Memory and can be accessed by the co-processor during the Deep-sleep mode.
- 1 Kbit of eFuse: 256 bits are used for the system (MAC address and chip configuration) and the remaining 768 bits are reserved for customer applications, including flash-encryption and chip-ID.
- Hardware:
- Module interfaces: SD card, UART, SPI, SDIO, I2C, LED PWM, Motor PWM, I2S, IR, pulse counter, GPIO, capacitive touch sensor, ADC, DAC
- 4 MB SPI flash
- Operating supply voltage: 3.0 V to 3.6 V
- Recommended operating temperature range: -40 °C to +85 °C
- Wi-Fi:
- Protocols: 802.11 b/g/n (802.11n up to 150 Mbps); A-MPDU and A-MSDU aggregation and 0.4 µs guard interval support
- Frequency range: 2.4 GHz ~ 2.5 GHz
- Bluetooth:
- Protocols: Bluetooth v4.2 BR/EDR and BLE specification
- Radio: NZIF receiver with –97 dBm sensitivity; Class-1, class-2, and class-3 transmitter; AFH
- Audio: CVSD and SBC
- Certification:
- Bluetooth certification: BQB
- Wi-Fi certification: Wi-Fi Alliance
- RF certification: FCC/CE-RED/SRRC/IC/MIC
- Green certification: REACH/RoHS
more information: https://www.espressif.com/sites/default/files/documentation/esp32-wroom-32e_esp32-wroom-32ue_datasheet_en.pdf
Login
