![Extended battery life in portable devices with new low Iq LDO Extended battery life in portable devices with new low Iq LDO](https://www.electronics-lab.com/wp-content/uploads/2018/10/r2-181012-apid-pr-mcp1811-7x5-1024x731.jpg)
Extending battery life in portable devices up to four times longer than traditional ultra-low quiescent (Iq) LDOs, Microchip has announced a linear Low Dropout (LDO) regulator.
With an ultra-low Iq of 250nA versus the approximate 1uA operation of traditional devices, the MCP1811 LDO reduces quiescent current to save battery life, enabling end-users to recharge or replace batteries less often. The minimised power consumption enables portable electronic devices to run for months or even years on a single battery.
Well suited for IoT and battery-operated applications such as wearables, remotes and hearing aids, the 250nA ultra-low Iq reduces power consumption in applications by minimising standby or shutdown current.
Reducing standby power consumption is critical in remote, battery-powered sensor nodes, where battery replacement is difficult and operating life requirements are high.
Available in package options as small as 1x1mm, the MCP1811 consumes minimal board space to meet the needs of today’s compact portable electronic designs. Depending on the application and number of LDOs, designers can take advantage of the extra board space with a larger battery to further increase battery life.
An additional benefit offered by the MCP1811 is faster load line and transient response when compared to other ultra-low Iq LDOs. Faster response times can accelerate wake-up speed in devices such as monitors or sensors that require immediate attention.
Faster transient response can help designers to avoid undervoltage and overvoltage lockout measures used in sensitive applications where transient spikes can result it catastrophic results.
- Ultra-Low Quiescent Current: 250 nA (typical)
- Ultra-Low Shutdown Supply Current: 10 nA typ (MCP1811A) and 5 nA typ (MCP1811B)
- Input Voltage Range: 1.8V to 5.5V
- Standard Output Voltages: 1.0V, 1.2V, 1.8V, 2.0V, 2.5V, 2.8V, 3.0V, 3.3V and 4.0V
- Low Dropout Voltage: 400 mV (typical) w/ Small Variation Over Load Range
- Stable with Ceramic Output Capacitor: 1.0 uF
- Overcurrent Protection w/ Foldback
- Output Discharge (MCP1811A)
- Available in 3 and 5 lead SOT-23, 3 and 5 lead SC70, 4 lead 1x1mm UDFN
more info: www.microchip.com
