![Finger heart rate and pulse oximeter smart sensor with digital signal processing Finger heart rate and pulse oximeter smart sensor with digital signal processing](https://www.electronics-lab.com/wp-content/uploads/2019/12/MAXREFDES220-maximintegrated.jpg)
The MAX77860 is a high-performance single input switch mode charger that features USB Type-C CC detection capability in addition to reverse boost capability and a Safeout LDO.
The MAXREFDES220# reference design provides everything you need to quickly prototype your product to measure finger-based heart rate and blood oxygen saturation level (SpO2).
The MAX30101 and the MAX32664 provide an integrated hardware and software solution for multiple finger-based applications. The MAX32664 firmware provides digital signal processing to process the data. The reference design also includes a tri-axis accelerometer to compensate for motion artifacts.
Key features
- MAX30101 Heart Rate Monitor and Pulse Oximeter
- Tiny 5.6mm × 3.3mm × 1.55mm 14-Pin Optical Module
- Integrated Cover Glass for Optimal, Robust Performance
- Ultra-Low Power Operation for Mobile Devices (< 1mW)
- Programmable Sample Rate and LED Current for Power Savings
- High SNR (Signal-to-Noise) ratio, typically greater than 80dB
- MAX32664 Sensor Hub
- Maxim-licensed firmware provides complete algorithmic support for finger heart rate and blood oxygen saturation calculations
- Communicates with host controller over industry standard I2C interface
- Secure firmware updates authenticated by dedicated bootloader
- 3-Axis Accelerometer Provides Greater Accuracy
- Compensates for motion artifacts
A MAX32630FTHR is provided to emulate a host system for easy development.
Design files, firmware, and software can be found on the Design Resources tab. The board is also available for purchase.
