![Flipper Zero Gains Wi-Fi Capability with Wi-Fi Dev Board Pro Flipper Zero Gains Wi-Fi Capability with Wi-Fi Dev Board Pro](https://www.electronics-lab.com/wp-content/uploads/2023/12/2023-01-20T16_41_52.567Z-IMG_2264-Copy.jpeg)
JustCallMeKoko, a developer and YouTuber, recently showcased Wi-Fi Dev Board Pro a new extension board for the Flipper Zero. Powered by an ESP32, this board adds Wi-Fi and Bluetooth capabilities to the Flipper Zero module. Priced at $40, this compact board comes with the ESP32 Marauder Firmware pre-installed.
The ESP32 Marauder is a device used for Wi-Fi and Bluetooth Pen testing, capable of scanning networks, monitoring packets, performing de-authentication attacks, and sniffing Bluetooth communications.
The Wi-Fi Dev Board Pro also offers upgrades for better portability and usability with Flipper Zero. Its header pins are mounted underneath, enabling a slimmer, secure fit. It also includes a micro SD slot, which reduces the need for soldering. An optional 3D printed enclosure adds protection, keeping a compact size.
The board connects to Flipper Zero’s expansion header, enabling access to Marauder CLI through a USB connection or the Wi-Fi Marauder app.
The Tindy page talks about the No Silicone Option, Choosing “yes” gives you a Dev Board Pro with lower profile pins for a closer fit to Flipper Zero, but it won’t work with a silicone case. This option is for those who prefer a more compact, caseless setup.
Wi-Fi Dev Board Pro Features:
- Flipper Zero compatible Header pins
- Standard ESP32-WROOM (includes BT)
- WS2812-2020 RGB LED
- Micro SD Card Slot
- ESP32 GPIO Breakout
- JTAG Interface
- UART Activity LEDs
- 3D Printed enclosure
The package comes with one assembled ESP32 WiFi Dev Board Pro and one assembled 3D Printed Enclosure, offering a complete set for immediate use.
The product’s documentation and source code are accessible on GitHub. The board is priced at $40 and can be bought from Tindy.
