![GAN039-650NTB is a 650 V, 33 mOhm Gallium Nitride (GaN) FET GAN039-650NTB is a 650 V, 33 mOhm Gallium Nitride (GaN) FET](https://www.electronics-lab.com/wp-content/uploads/2022/06/nexperia-gan039-650ntb.jpg)
The GAN039-650NTB is a 650 V, 33 mΩ Gallium Nitride (GaN) FET in a CCPAK1212i inverted package. It is a normally-off device that combines Nexperia’s latest high-voltage GaN HEMT H2 technology and low-voltage silicon MOSFET technologies — offering superior reliability and performance.
Features & benefits
- Simplified driver design as standard level MOSFET gate drivers can be used:
- 0 V to 12 V drive voltage
- Gate threshold voltage VGSth of 4 V
- Robust gate oxide with ±20 V VGS rating
- High gate threshold voltage of 4 V for gate bounce immunity
- Low body diode Vf for reduced losses and simplified dead-time adjustments
- Transient over-voltage capability for increased robustness
- CCPAK package technology:
- Improved reliability, with reduced Rth(j-mb) for optimal cooling
- Lower inductances for lower switching losses and EMI
- 175 °C maximum junction temperature
- High Board Level Reliability absorbing mechanical stress during thermal cycling, unlike traditional QFN packages
- Visual (AOI) soldering inspection, no need for expensive x-ray equipment
- Easy solder wetting for good mechanical solder joints
Applications
- Hard and soft-switching converters for industrial and datacom power
- Bridgeless totempole PFC
- PV and UPS inverters
- Servo motor drives
more information: https://www.nexperia.com/products/gan-fets/GAN039-650NTB.html
Login
