![GaO beats SiC in channel mobility GaO beats SiC in channel mobility](https://www.electronics-lab.com/wp-content/uploads/2020/01/gaomosfet630_0.jpg)
Startup company Flosfia has reported that its gallium-oxide power semiconductor can outperform the characteristics of silicon-carbide, but in a normally-off configuration.
Flosfia Ltd. (Tokyo, Japan), founded in 2011, is a pioneer of the use of corundum-structured gallium oxide (α-Ga2O3) as a power semiconductor. The company said it has achieved a channel mobility of 72cm2/Vs in normal-off operation which it compares to 30cm2/Vs for silicon-carbide.
Whereas other power semiconductors may need the power to be applied to turn-off the transistor having a technology that turns off when no voltage is applied to the gate is an important characteristic of power transistors for safe and secure electrical systems.
Flosfia calculated the characteristic on-resistance of GaO MOSFETs with a withstand voltage of 600V to 1200V by device simulation and found that the on-resistance was approximately 50 percent or less that of commercially available SiC.
Flosfia has signed an agreement with Hakuto and Kyoei Sangyo for these two companies to handle corundum-type gallium oxide power devices as domestic distributors.
more: www.flosfia.com
